Rendering Enviroment And Materials
I am pretty new at both Rhino And Brazil. I applied some Brazil render materials but as an example the grass is blown out of proportion when applied to the surface and the same goes for the brick material I used on the building. I also don’t understand how to make use of HDRI images and how to properly apply other environments. Its almost like the environment is on an infinity setting, if that makes sense. Like I said I am very new at this and have a 1000 questions.
Thanx.
Roelof
This is the best place to post - but I’d suggest you send images to show what you mean, because without them it’s all guesswork.
Before you carry on, make sure you take a look at the video tutorials that we have online at http://brazil.mcneel.com - for example: http://brazil.rhino3d.com/video/an-introduction-to-brazil-for
Andy
Andy,
Thanks for the reply. I have watched most of the tutorials but I will definitely run through them again. Will get back to you.
Roelof
