ian4569
(Ian4569)
1
I have this strange reflection effect on my material in shaded mode. How can I disable it. I cannot see anything clearly with this.
I just want to preveiw the texture maps without any lighting effect. C
Can anyone tell me how to do that?
The lighting method is “no lighting”!
Shaded.ini (13.9 KB)
Thanks
pascal
(Pascal Golay)
2
Hello- it looks like your mode is set to use rendering marterials -
those will reflect the environment if reflective…
ian4569
(Ian4569)
3
Hi Pascal,
Thanks for the reply.
Is there a way to preview the materials without the reflection?
I just want to see if the material mapping is correct. This makes it hard to do that.
Thanks!
nathanletwory
(Nathan 'jesterKing' Letwory)
4
Make sure you don’t have a custom environment for reflection set, nor for skylighting. That should help.
ian4569
(Ian4569)
5
Thanks! It worked!
Just deleted whatever was in the environment panel.
