In ‘rendered’ view (real time render viewing) using the scene lighting with skylight on within an environment, I can’t seem to smooth out the shadows. Is there a way to smooth these out?
I’ve tried to max out the
The attached shows an interior section with a 2 walls and a ceiling - one wall has window cut-outs from where most of the light from the environment is entering the space.
you can amp the hdri multiplier for the environment and you’ll get a bit more fill in the shadows with neon. Also a classic trick is to use the - version of capturetofile and then scal up 2 or 4 times the final output size.
Enter file name, click “Save” and you should see the option in next step, look at the command prompt (providing that you used hyphen before command name).
