Im trying to render an object in using the default rendering engine in Rhino. For some reason the rendered image that is produced is actually worse than the default rendered view… The shadows get very sharp and have no depth. Any one know what could be wrong?
I’ve attached an image.
Thanks in advance!
pascal
(Pascal Golay)
November 15, 2016, 6:46pm
2
Hi Oskar - if skylight is on for the full render, it should avoid the fully black shadows, but it will take noticeably longer to render.
(DocumentProperties
> Rhino Render page)
Thanks pascal for your input! I appriciate it. Unfortunately it did not help I really just want the image as displayed in the viewport in high resolution on a transparent background. The image im trying to render is a section cut of a volume, could that be the issue?
pascal
(Pascal Golay)
November 15, 2016, 7:33pm
4
Hi Oskar - here is what I get-
Is that about right?
That looks alot better than what i get…
On an other note… did you create that strcture by joining spheres and using the fillet surface command?
pascal
(Pascal Golay)
November 15, 2016, 7:40pm
6
Hi Oskar - try setting an environment, I used ‘Studio’ in the Environment panel, then add a light to your scene -
OskarTest.zip (4.1 MB)
Hmm - sorry about the file size - it must be the hdr image in the environment. Checking…
The rendering works fine in your file!
Here’s a link to my file if you want to have a go https://we.tl/owBElMSvxf
pascal
(Pascal Golay)
November 15, 2016, 9:36pm
8
Hi Oskar - turn on Skylight in the Lights panel (slow!), and add a spotlight to cast shadows (or the Sun) and it should look better.
Thank you Pascal! Is there a way where you can just get a high res image in the same manor as the model is displayed in viewport?
pascal
(Pascal Golay)
November 15, 2016, 10:16pm
10
Hi Oskar - use the command
_-ViewCaptureToFile
With a dash “-” in front. Set the image size at the command line, among other things…
May I ask what is this model of?
sw.enscape
(Aish Enscape)
February 9, 2018, 2:27pm
12
Enscape can help you achieve amazing quality renderings with Rhino at a fast speed! Here you can know about the tool - https://enscape3d.com/real-time-rendering-and-virtual-reality-with-rhino/ .
