In the render my shadows are to dark. I cannot find anything directly at the fora. Brazil or Neon does not work.
How can I fix this?
Making them more transparent? How?
Hi floris - Iâd say you need some form of global illumination from the environment - Brazil can do this.
I tried also background color or ambient light, but I still cannot figure it out
Hi Floris - try checking the âSkylightâ box in the QMC sampler. In any case - see
https://wiki.mcneel.com/brazil/gettingstarted
First thing that wonât really fix the problem but is good to do is change the gamma setting in document properties to 2.2 from 1.
Beyond that⌠what sort of lighting are you using? What are the âwindowsâ ? Is everything modeled in real life scale?
Everything is modeled in real life scale, open windows. Directional light, point light.
I will now try the gamma change (in brazil settings?)
I tried, maybe I have to make more time. But, it seems really difficult. Maybe you have a tip, I will continue to follow the guide you provided.
There are numerous places in Brazil to tweak gamma for various things, but Iâm talking about the global rendering setting in DoucumentProperties, under the Rendering tab.
Looking at your settings above, a number of them need changes just to start. Turn off âDefault Lighting,â turn ON âDirect Illumination,â and probably while you are learning turn off photons and see what you can do by brute-force upping the QMC samples and bounces, which will give you a better Neon preview since it doesnât use photons. Photons can speed things up dramatically for scenes with a lot of indirect light, but they can take a lot of tweaking to get working properly, and you kinda need to know what âbrute-forceâ looks like to know what youâre trying to improve upon, there are tutorials for Brazil for Max on the net that are applicable.
Well, the site I was going to point to for Brazil for Max tutorials seems to be gone. Well, if you could share the file or some more context on what youâre trying to achieve someone will be able to helpâŚ
Us Brazil users canât be of much help is we donât have your file to play with.
Danny
