Hey guys,
I’m having some troubles with my displayport settings. Im trying to a clean and proper light studie on my model but once I put the soft edge quality to sharpest, the entire quality of shades and forms get deformed. Could this be an issue with my gfx settings or am I missing something? Im running a 1060gtx so it should run rather smoothly.
With edge quality at the sharpets
With edge quality just one tick to the right. (The graphics are still failing somewhat, as you can see on the ground plane in the corners.)
My settings
Rendered.ini (11.4 KB)
My setup
Rhino 6 SR12 2019-1-29 (Rhino 6, 6.12.19029.6381, Git hash:master @ ae9d7fba5fda0b43002dc44a34e059a9a382db04)
License type: Evaluation, build 2019-01-29
License details: Cloud Zoo. In use by: filip.heim ()
Expires on: 2019-05-18
Windows 10.0 SR0.0 or greater (Physical RAM: 24Gb)
Machine name:
Non-hybrid graphics.
Primary display and OpenGL: NVIDIA GeForce GTX 1060 (NVidia) Memory: 6GB, Driver date: 12-11-2018 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 417.35
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 12-11-2018
Driver Version: 25.21.14.1735
Z-Buffer depth: 24 bits
Total Video Memory: 6 GB
Im also having an issue with the arctic viewport which turns black randomly when panning around in the viewport. Simply swapping back and forth to another displaymode gets arcticview back to normal, but its still an irritating glitch
Thanks for the help!
Kind regards,
Filip
