Render Rhino dimensions in Vray
Is it possible to render just dimensions in Vray?
I have found an old topics of 2016 which suggested some options that does not work as today.
Dimensions (Annotative, if that’s what you mean) are not 3D objects, just bunch of lines and text. Thus they cannot be rendered.
Yes, I meant annotative, sorry.
Thanks for the reply btw
if you extrude the text and make the lines pipes or cylinders - 3D objects, assign materials ( or use the default) - the that would be rendered. However you must explode the dimension object. I would rather write a script to do that in a temp file.
I hoped something more direct but this can make it as well, thanks!
