Hi I would like to render Rhino 5 text objects using VRay for Rhino ver.2 and can`t seem to find a way to do it. VRay support suggest that text will render if converted to an object. Not sure what this means. Same issue for curves and wireframes.
Many thanks
Try to explode, it will convert text to curves, which you can extrude to solids.
Hi Yianni and thanks for the help. Your solution worked. Any idea how to render curves and wireframes in Vray.
mcmc
I have same problem. I need to render Rhino text object with V-ray 2.0. Have you find a solution for this?
