Hi all, I have no idea why since last week, all my models display as transparent in the render mode (as shown on the image). I tried “Restore Defaults” and re-install the Rhino7 but with no luck – the issue is still there… Does any body have the similar issue as I did?
The Shaded and Arctic Mode is fine but the Render mode is not…
I am sure it is not the issue of just this rhino file, because this issue happens on all different rhino model files on dfferent project.
The mesh normals might be flipped outside in.
Can you please show the settings panel of render mode viewport?
Check transparent value in the panel settings.
But it happens on every single polysurface, I didn’t flip all of them… and also for the very old models like one year ago, which displayed correctly – they all display as transparent now. So I think it is a setting issue.
Hi Jack - if you make a box, brand new in a new file… does it look right? If so, please post one that does not…
i am having same issue. Is the model far from origin?
Why don’t you post a Rhino file and your system info?
Hi foreigner, thanks for your prompt reply. I have done a few screenshots (not sure where is the transparent value) see if I can change some of the parameter to fix it?
I tried with one box on a new rhino file, it still show the error.
One Box.3dm (29.1 KB)
Below are the system info:
Rhino 7 SR13 2021-12-14 (Rhino 7, 7.13.21348.13001, Git hash:master @ 7696723f74a63695b3c372a89110c0ca8c78b890)
License type: Commercial, build 2021-12-14
License details: Stand-Alone
Windows 10.0.19044 SR0.0 or greater (Physical RAM: 32Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 3060 (NVidia) Memory: 12GB, Driver date: 4-20-2022 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 512.59
- Secondary monitor attached to adapter port #0
- Windows Main Display attached to adapter port #1
Secondary graphics devices.
Intel(R) UHD Graphics 630 (Intel) Memory: 1GB, Driver date: 8-20-2021 (M-D-Y).
- There are no monitors attached to this device!
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 4-20-2022
Driver Version: 30.0.15.1259
Z-Buffer depth: 24 bits
Total Video Memory: 12 GB
C:\Program Files\Enscape\Bin64\Enscape.Rhino7.Plugin.dll “Enscape.Rhino7.Plugin” 0.0.21349.1646
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.13.21348.13001
C:\Program Files\Rhino 7\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 7\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 7\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.13.21348.13001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.13.21348.13001
C:\Program Files\Rhino 7\Plug-ins\Alerter.rhp “Alerter”
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.13.21348.13001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.13.21348.13001
Start with the low hanging fruit by updating your Rhino.
You’re on SR13, nine months behind on updates.
The current release is SR22 (I think).
Hi Jack - if updating Rhino does not do it, please try blocking Enscape in the plug-ins page of Options, close and re-open Rhino… ?
