Rendered Display Mode changed suddenly
Suddenly objects in particular layers appear translucent, nearly invisible in Rendered display mode. Not all layers are affected.
Rhino Version 5 SR14 64-bit
(5.14.522.8390, 5/22/2017)
Windows 10 Pro (noticed after an update to Windows 10, might be video drivers), however dxdiag reported no problems found. I see that there are no updates for the ATI Radeon HD 2400 XT display adapter for Windows 10 Version 10.0.19042 Build 19042 in a Dell Precision Workstation T3400.
DirectX Version is DirectX 12
Thanks,
David
Hi David - is this true with any model? Is the display mode set at defaults ?
Hello Pascal
A different model of the same objects appears to be okay. I clicked on Restore Defaults in the affected model. It didn’t seem to help.
Thanks.
David
Hi David - can you export one or two of the funny ones to a new file, check that and it is also looks wrong, post it here or send to tech@mcneel.com, with a link back here in your comments.
Yessir. Thanks. I’ll send them to tech@mcneel.com to see what Vanessa thinks about 'em.
Regards,
David
answered via tech support
Kyle responded via email:
“…there is a duplicated surface which caused a bad trim in the flat surfaces.
explode the object, run the seldup command you will see this surface light up. delete it and you will see this surface light up-…”
I tried that but I didn’t have any luck at it. Thankfully, Kyle fixed it, attached the file in his email and all is well again in Saucerville.
Thanks,
David
(changed solution to the post above, since it has the actual solution in :wink: )
