Render issues in the SR22 RC
I noticed that the quality of a rendering I’m working on took a big nosedive in the SR22 RC. Take a look:
I tried on a computer with SR21 and it looks good (as it did on my computer before upgrading to the SR22 RC)
Anyone else seeing this? I see it both when rendering or when running the raytrace display mode.
I can reproduce this with a simple box:
Thanks,
Dan
Hi Dan -
I’m not seeing something like that with a simple box with some material on 7.22.
To be sure, could you post that file?
Hi @wim
I’ll attach a file for this model:
For Wim.3dm (5.7 MB)
I’m trying to recall changing any settings that might have cause this to misbehave, but I don’t believe that I did. I successfully rendered my project on Monday, didn’t get back into until this morning, but I did do the update to the SR22 RC yesterday. Keep in mind that I know next to nothing about rendering, so it could definitely be user error somehow.
Thanks,
Dan
Hi @DanBayn ,
I tried your file here and had no issue. Are you using the CPU or GPU for Raytraced? Check Options > Cycles for the compute device used. Try the CPU if you are set to GPU, it could be a GPU driver issue after the update requiring you to update that driver too. Other thoughts are if you have multiple monitors connected or are using another renderer than the Rhino Renderer. We can also roll you back to SR21 to see if that indeed solves the issue. If it does, we’ll need your SystemInfo results which you can email to tech@mcneel.com if you don’t want to upload that here.
Hi @BrianJ,
Thanks for the suggestions. It turned out to be the graphics driver. I didn’t originally suspect that because the driver was only about 6 weeks old. But there was a newer one that is about 3 weeks old so I installed that. The renderings look good again.
Thanks,
Dan
Hi Dan -
Thanks for letting us know. Do you have more information about the buggy driver and your GPU? That might be handy information to have when others run into this.
I have an Nvidia Quadro P2000. The 516.59 driver from the beginning of July was the problematic one. The latest from the end of July is 516.94. This is the one that works. I also run the driver with the dynamic streaming set.
Seems I also have this issue with GPU rendering only (CPU is fine, but slow).
Admittedly it has been a couple weeks since needing the ray tracer, so i am unsure when it started.
I started with the things above like updating the drivers for my Quadro P3200 as well as the intel integrated, but still see the issue with Cycles. Legacy Renderer seems to be working fine as a note.
this one is just an example, this same thing happens on all objects in raytrace mode and within the rendering window
interesting thing here:
If i copy the objects and paste them in place 5-6 times, it starts to clear up
if you copy the results of the Rhino command _SystemInfo here we can maybe see what the issue is with the graphicall drawing issues. Most likely still you aren’t using the latest possible driver for your GPU.
Rhino 7 SR22 2022-8-12 (Rhino 7, 7.22.22224.07001, Git hash:master @ 511a45af0c696f2c15a3e5a9bda0bb8bfb324b3f)
License type: Commercial, build 2022-08-12
License details: Cloud Zoo
Windows 10 (10.0.19042 SR0.0) or greater (Physical RAM: 32Gb)
Computer platform: LAPTOP - Plugged in [95% battery remaining]
Primary display: Intel(R) UHD Graphics 630 (Intel) Memory: 1GB, Driver date: 7-19-2022 (M-D-Y).
Primary OpenGL: NVIDIA Quadro P3200 (NVidia) Memory: 6GB, Driver date: 7-21-2022 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 516.94
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 7-21-2022
Driver Version: 31.0.15.1694
Z-Buffer depth: 24 bits
Total Video Memory: 6 GB
C:\Users\greg.callahan\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\NVIDIADenoiser\0.4.0\NVIDIADenoiser.Windows.rhp “NVIDIADenoiser.Windows” 0.4.0.0
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.22.22224.7001
C:\Program Files\Rhino 7\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 7\Plug-ins\RhinoBonusTools.rhp “Rhino Bonus Tools”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.22.22224.7001
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.22.22224.7001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.22.22224.7001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.22.22224.7001
it says that it;s from last month, but i checked again on their site and the version is the latest.
Perhaps I should try the “New Features” branch drivers.
You are using the same driver I updated to.
This is superseded, current version is 0.4.3. May be worth trying an update via the package manager.
I took that plugin completely out and uninstalled the plugin to rule that out.
I still have the issue while rendering or in raytrace mode.
Updated SysInfo:
Secondary graphics devices.
DisplayLink USB Device (DisplayLink) Memory: 0MB, Driver date: 8-11-2021 (M-D-Y).
> External USB display device with 2 adapter port(s)
- Secondary monitor attached to adapter port #0
> External USB display device with 0 adapter port(s)
- There are no monitors attached to this device. Laptop lid is probably closed
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 4.6
The SRC22 that comes out (hopefully) today should have the render articfacts fixed.
That’s exciting, thanks for the update and i’ll keep a lookout for it.
Got the update, and it is much much better.
Still a bunch of the fancy garbled rectangles appear.
I’ll look more to see if there is a render setting that’s causing this.
I dont know how exact the Blender Cycles is to the Rhino Version, but i went into blender 3.2.2 and did a GPU render there in both OPTIX mode as well as CUDA. All came out well there.
I also went ahead and downloaded/re-installed GPU drivers.
I can just use blender for now, just another step.
can you try it with the 2nd monitor unplugged and see if it does the same thing with just the laptop monitor?
also are you set up correctly here?
