I’ve been trying to make smooth surfaces between two circular curves:
These curves can also be of different diameters. Currently I use the function RuledSurface
but it seems like there is always a seem connecting the two curves. I know this is standard way that Rhino maps surfaces but I was wondering if anyone knows a way to get around this issue? It seems trivial but it is quite an important detail for what Im working on. Meshing will also not work as I need the surface between the two curves to be a single surface and not multiple
