Hi, is there any method to turn a trimmed surface into a regular surface, at the same time remained the part that is unwanted? It is because a trimmed surface often become troublesome when we want to create uniform cells on it.
I am looking for a way to create uniform cells on this surface, appreciate advice from you guys,
Hi Akilli thanks for your reply.
That was a great help for the first step my problem, but what I intended to do is to map those panels on that surface(you’ll saw them in my GH file, the group that label as ‘Panels’).
When I try to map them up, all those cells turns out stretched instead of remained uniform.
Do you know how to make them regular?
