It is cut at the same height as the plan and looking down like the plan, so the section cut from the plan and the RCP are an exact copy of each other, but the bit that is interesting is it’s like you have a mirror on the floor. If you look at the plan and the RCP below, you can see the section cut is not flipped, as it would be if the view of the ceiling was done using a bottom view.
