I’ve encountered an issue where Revit starts crashing after some time when I begin drawing or selecting objects in the Rhino viewport. After spending a few hours checking whether the problem was caused by my script or any referenced elements, I identified the cause.
Whenever I reference a linked .dwg file and then draw a line or make changes, switch viewports, or perform mouse clicks, Rhino freezes and Revit crashes.
I’m not ruling out other factors that might contribute to this problem, but I’ve tried to reproduce the situation with as few external influences as possible.
In addition, I must point out that I’ve just noticed this crash occurs with standard generic models, not only with DWG links. I just can’t replicate it yet to record the situation, it’s so random.
I don’t have a minidump file, as mentioned in the “Help Us Help You” topic, but I do have another dump file (“journal”) and the corresponding TXT file. I’ve attached the files below.
I’d be grateful if you could help me find the reason for this error, because I’m currently unable to use Rhino.Inside in this situation.
I managed to replicate the Revit crash in an almost original environment. Only a few basic Grasshopper plugins are active, but I couldn’t delete them because they weren’t in the Libraries folder. However, I don’t think they are the cause of the problem.
You can skip the video from 1:29 to 2:00 — I was attaching my reference file on the second screen
P.S.
Update:
I thought that something might be wrong with my linked files because they use actual geographical coordinates. So I created a basic AutoCAD DWG file near the origin and linked it to Revit, but the result is the same.
Not only on remote desktop @Japhy. I just checked SystemInfo with remote desktop because I’m not at the office. However I checked both at pc and remotely, and this crash occured. If it makes any difference, I can send SystemInfo report directly from the PC tomorrow.
