Hi! I accidently undocked the panels on the right (layers, material, properties, etc.) and I don’t know how to put it back. I don’t want it floating because the icons at the top are too small. I want to put it back on the right. What do I need to do? Rhino 8 Thanks!
To redock, drag the floating container to the right on top of a blue rectangle that appears. Alternatively, double clicking the small dots in the upper right corner should also make it redock where you dragged it from.
A third option is to reset the Window Layout to the default Window Layout in Window > Window Layouts > Default Window Layout
Yeah I found it. Duh me!
But THANK you for the very quick response! After I corrected it I decided to hook up my wife’s QHD monitor to move things around. WOW! That’s awesome to have the extra screen! Would you know how to make the icons and tools on the tool bar I move to the 2nd screen larger? My main monitor is a 32" 4K and the 2nd screen is a 27" QHD (2560x1440). Again, thank you for the very fast and friendly response!
You cannot scale icons per display. If the icons are too small on the extra monitor, use a larger display scaling for that monitor.
