Small bug that didn’t get fixed in the last sr, I don’t know if it was reported? Panels aren’t redrawing on my second monitor unless I click a tab first then all is ok.
I move the panels onto my second monitor
If I double click them to bring them back to my original monitor
they dock on the left side.
But when I double click to get the panels to go automatically back to my second monitor where they were positioned only half of the active panel gets redrawn. I have to click a tab on the panels to get the panels to redraw properly.
Thanks for this report. I’ll need to get a dual monitor set up running to test this out. @JohnM, have you seen this if you happen to have a second monitor running?
Hi John,
I’m now on Chrome so I can now post files, here are a couple of screen shots.
Thanks for taking a look,
RM
Windows Vista, 32bit RhinoV5 latest SR
Two things, didn’t know you could do that with a double click. Pretty cool. Secondly, this doesn’t require two screens for this to happen (or at least, the panel getting restored doesn’t need to go to the second screen to see the effect, I have two screens and didn’t turn off the second, but it appears that the two screenedness isn’t part of it).
The area that is getting redrawn is the width of the panel in the docked state. So here, when I dock it on the left, make it rather narrow, then restore with a double click, only the area visible when it is docked will be drawn. It doesn’t matter what screen it is getting restored to.
I have reproduced this here and filed the issue as RH-20590. This report is not publicly visible at this time.
I was misunderstanding what was being done and indeed it can be seen on a single monitor as Sam pointed out. If you have a docked panel collection and double click the top edge to float that collection, the floated arrangement only redraws at the width of what was docked.
Displayed the Layers, Properties and Libraries tabs in a container docked on the right side of a maximized Rhino
Dragged the docked container to my second monitor
Made sure the floating container was narrower than the docked version
Double clicked on the title bar to get it to dock in its previous position
Double click the gripper at the top of the docked container to float the container
Repeated steps 4 and 5 several times
I was not able to see the gray area on my Windows 8 computer but I heard there may be another developer in the building who can reproduce this so I will see if I can track it down. Are those the correct steps to reproduce the problem?
