Reading enhancement
I wonder if that area (green) could be optimized by enlarging value boxes to fill empty and unused area. Even if we could adjust the column width to partially hide the field names, that would be fine, because over time we don’t need to see them fully.
I use long names and I rarely see it entirely.
Regards
Even this would be better:
That extra space probably exists because Rhino is available in a bunch of languages and some of the description names will be longer than the English ones.
Probably but pretty sure there is a better solution to that.
Dunno, not being one who can program UI elements, I don’t know what’s involved.
Edit: In playing with it a bit, both the right and left columns seem to expand proportionally to the width given to the panel. That is probably an incorrect way to do it, I agree, the left (name) column width should probably be fixed to that of the longest description and the right side dropdown fields allowed to expand and contract with the panel width.
The Rhino UI lacks any kind of responsiveness. Since quite some time, responsive UI is a basic design philosophy or aspect and Rhino just can’t bother to integrate it. This is just one tiny example where the lack of it becomes annoying.
This shows how far behind the curve the McNeel team is.
In case that the field for the text on the left side is shorter than the longest text, howering over the partially visible text should show the full text. This is the standard behavior in many programs, including programs for graphic design, audio players and video players. This also happens even if the user hovers the mouse pointer over an icon instead of a partially visible text.
I would love to see it implemented in Rhino’s UI wherever it is needed.
That should be the case if the panel is pulled very narrow so that it’s not possible to see the entire longest label. IMO it is important to see the full label name (left column) as a priority, in order to know what one is looking at/setting. Once the panel is pulled out so the left (label) column width is as wide as the longest description, then the right column with the settings/dropdowns should start to widen.
