In the current rhino8 (8 SR3 8.3.24009.15001) it’s not possible to change the fields in size. Many of my layers are longer than the box and I don’t want to make the hole panel wider. This makes it difficult to see what layer that object is in. In rhino 7 you could move the start.
Personally I think these fields should be as big as possible, leaving the space behind the text is a waste of space. Especially on smaller screens (laptops), this problem is worse.
rhino 7 with moveable option
rhino 8 + suggested solution
Hopefully this is possible. Thank you in advance
Martijn
