Is there a setting to change this column width?
Seems a little narrow to me. It’s almost truncating the images.
Thanks,
Dan
Compare this to V6:
I’m hoping the UI is still in development, because V7 looks nasty in this area. I also don’t understand why the tabs would not maintain the look of the toolbars or viewport tabs:
Thanks,
Dan
@brian and @johnc you may want to take a look at this one. I didn’t test the recent panel tab changes with tabs oriented on the side.
Yep, Dan we’re going through some restyling at the moment. Nothing too major, but these things are good to catch so thanks.
I did test vertical mode but I must have missed this case.
I’ll get it fixed ASAP.
John
@DanBayn yes, it’s changing. The Rhino 7 tab styling for panels has changed a lot. One thing we haven’t changed yet are the default colors, which will also improve the look of these elements. The goal here is to get rid of a lot of the extra pixels throughout the UI.
That said, the square vs angled tabs is intentional.
Rather than going into each of the details, please see what you think of next week’s build…
I filed a bug report for this:
https://mcneel.myjetbrains.com/youtrack/issue/RH-60647
John
Hi
There are spaces. Last updated wip
I’m looking forward to see what’s coming up.
Thanks,
Dan
Hi -
That is by design so that nothing starts jumping around when you select and deselect the “Sub-objects” checkbox.
