Read and Write Nudge Key Option via Python
Hi all,
is there a possibility to access and change the Nudge Key Options via Python? There are methods in the Rhino SDK for C# and VisualBasic. I like to try a toolbox/script for immediate change during modelling.
Thank you in advance,
fishermans.
Yes.
import Rhino
#get current setting
nudge_step=Rhino.ApplicationSettings.ModelAidSettings.NudgeKeyStep
#set new value
Rhino.ApplicationSettings.ModelAidSettings.NudgeKeyStep=value
There are also
ModelAidSettings.CtrlNudgeKeyStep
ModelAidSettings.ShiftNudgeKeyStep
for the other two settings.
HTH,
–Mitch
Basically, anything that you find in RhinoCommon can be done in Python.
Mitch,
great! You were much to fast for me.
Thank you,
Norbert.
So here I am now. Next would be, to make it - like object snap - persistent and usable same time with other commands. Is there any advice for that? I guess this is going to be much harder.
Norbert.
import Rhino
ctrl_nudge_step=Rhino.ApplicationSettings.ModelAidSettings.CtrlNudgeKeyStep
shift_nudge_step=Rhino.ApplicationSettings.ModelAidSettings.ShiftNudgeKeyStep
arr_value_text=[]
arr_value_text.append("Arrow Value")
arr_value_text.append("Ctrl+Arrow Value")
arr_value_text.append("Shift+Arrow Value")
arr_nudge_step=[]
arr_nudge_step.append(nudge_step)
arr_nudge_step.append(ctrl_nudge_step)
arr_nudge_step.append(shift_nudge_step)
arr_nudge_step = rs.PropertyListBox(arr_value_text,arr_nudge_step,"Nudge Key Values"," ")
nudge_step=float(arr_nudge_step [0])
ctrl_nudge_step=float(arr_nudge_step[1])
shift_nudge_step=float(arr_nudge_step[2])
#set new value
Rhino.ApplicationSettings.ModelAidSettings.NudgeKeyStep=nudge_step
Rhino.ApplicationSettings.ModelAidSettings.CtrlNudgeKeyStep=ctrl_nudge_step
Rhino.ApplicationSettings.ModelAidSettings.ShiftNudgeKeyStep=shift_nudge_step
print "Arrow Nudge: ",nudge_step,"  Ctrl+Arrow: ", ctrl_nudge_step,"  Shift+Arrow: ", shift_nudge_step
