Ray tracing with edges
I try to superimpose edges to rendering in raytracing display mode but I dont’ find .
When i tick surface edge in raytracing mode i see all the edge behind the solids like transparent mode.
When I use render display mode its works but i don’t see glass reflexion and shadow quality is better in ray tracing display mode.
Also i don’t no if its possible to modify textures saturation for one detailed view with raytracing or render mode.
Please run the Rhino command _SystemInfo and post the result in a reply.
Rhino 7 SR36 2023-12-12 (Rhino 7, 7.36.23346.16351, Git hash:master @ 11a364321297eb8cdb34405a3308d8911f58706d)
License type: Éducation, version 2023-12-12
License details: Cloud Zoo
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 16Gb)
Computer platform: LAPTOP - Plugged in [96% battery remaining]
Primary display and OpenGL: NVIDIA GeForce GTX 1660 Ti (NVidia) Memory: 6GB, Driver date: 1-18-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 551.23
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 1-18-2024
Driver Version: 31.0.15.5123
Z-Buffer depth: 24 bits
Total Video Memory: 6 GB
C:\Program Files\Rhino 7\Plug-ins\Tibidabo\Lands.rhp “Lands Design”
C:\Users\33686\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\NVIDIADenoiser\0.4.3\NVIDIADenoiser.Windows.rhp “NVIDIADenoiser.Windows” 0.4.3.0
C:\Program Files\Rhino 7\Plug-ins\Tibidabo\VisualARQ.rhp “VisualARQ”
C:\Program Files\Rhino 7\Plug-ins\Tibidabo\Tibidabo.rhp “Tibidabo”
C:\Users\33686\AppData\Roaming\McNeel\Rhinoceros\7.0\Plug-ins\D5Conv (e0d5e210-02f6-4ee9-a2b0-1675e225d958)\0.12.0.0028\Rhino 7\D5Conv.rhp “D5 Sync for Rhino”
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.36.23346.16351
C:\Program Files\Rhino 7\Plug-ins\WebBrowser.rhp “NavigateurInternet”
C:\Program Files\Rhino 7\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 7\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 7\Plug-ins\IdleProcessor.rhp “GestionnaireInactivité”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rendu de Rhino” 7.36.23346.16351
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp “Ancien rendu de Rhino”
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.36.23346.16351
C:\Program Files\Rhino 7\Plug-ins\Alerter.rhp “Alertes”
C:\Program Files\Rhino 7\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 7.36.23346.16351
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.36.23346.16351
C:\Program Files\Rhino 7\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 7.36.23346.16351
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.36.23346.16351
I try with simple volume, and a visual arq wall, its work for volume (just note for sphere). But don’t work for visual arq wall
Ah, this is an issue with Visual Arq. I don’t know how they are setting up the materials and geometry exactly, but to me it looks like it isn’t done entirely correctly. I’m changing category to VisualARQ
Hi @Henry_Boutet_de_Monv,
I see the problem. I’ll report it to find a solution; we’ll keep you posted.
Ok thanks
Hello Alfonso,
Have you find a solution ?
Thanks,
Henry
Hi @Henry_Boutet_de_Monv I think this works fine in Rhino 8. Have you tried it?
Hello Francesc,
Thanks, It works fine
Hi @fsalla,
I have again this bug with edge
when i make render
and other bug with plan section
https://www.dropbox.com/scl/fo/f91jiw4lrxtl81vtqu6wx/ANMBRleJw7ArnHlARskNJsE?rlkey=t840p141tizhwsg6c3xq4bopc&st=ztkyme6z&dl=0
@Henry_Boutet_de_Monv which display mode are you using in these screenshots? have you changed anything from the default settings?
This is how your model looks like in default’s Rendered display:
No also with default settings
Hi @Henry_Boutet_de_Monv I understand it now. This option to show the edges after a render seems to fail with VisualARQ objects. I’ll get back to you when we can fix it.
Hi @fsalla , ok thanks
I don’t see a failing render here from Rhino Render perspective. What am I missing?
@nathanletwory it’s the “Surface edges and isocurves” setting in the Post effects in Rhino render dialog. It seems to do not work properly with VisualARQ objects:
