Issue with Ray Traced mode with edges shown
Ray Traced With Edges Issue.3dm (11.7 MB)
Rhino 8 SR13 2024-11-12 (Rhino 8, 8.13.24317.13001, Git hash:master @ ca3666c3ebed2b9567e10930077bfa0884f65db9)
License type: Commercial, build 2024-11-12
License details: Cloud Zoo
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 15GB)
.NET 7.0.0
Computer platform: LAPTOP - Plugged in [80% battery remaining]
Primary display: AMD Radeon 780M Graphics (AMD) Memory: 1GB, Driver date: 7-24-2023 (M-D-Y).
Primary OpenGL: NVIDIA GeForce RTX 4070 Laptop GPU (NVidia) Memory: 8GB, Driver date: 2-22-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 546.80
Secondary graphics devices.
DisplayLink USB Device (DisplayLink) Memory: 0MB, Driver date: 4-16-2020 (M-D-Y).
> External USB display device with 1 adapter port(s)
- Secondary monitor attached to adapter port 0
> External USB display device with 0 adapter port(s)
- There are no monitors attached to this device. Laptop lid is probably closed
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 2-22-2024
Driver Version: 31.0.15.4680
Z-Buffer depth: 24 bits
Total Video Memory: 8188 MB
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.13.24317.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.13.24317.13001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.13.24317.13001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.13.24317.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.13.24317.13001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.13.24317.13001
C:\Program Files\Rhino 8\Plug-ins\BlockEdit.rhp “BlockEdit” 8.13.24317.13001
C:\Program Files\Rhino 8\Plug-ins\Calc.rhp “Calc”
Seems to occur on thinner objects but objects that do have some thickness.
I can’t reproduce on MacOS or Windows with an 8.15 build.
Windows:
MacOS (changed layer colors here to black):
edit: FWIW Raytraced/Rhino Render do not draw these lines, that is done by the display pipeline essentially as a postpro step.
In addition to getting the latest version available of Rhino, you might want to update your Nvida driver to see if that helps.
A new Rhino session and it’s gone.
Using linework with the Raytraced mode gives a good effect similar to what you can do with most real-time render engines.
Trying to add linework post-production… It didn’t work out too well but I think you guys have bigger fish to fry right now.
I recall a popup that I immediately closed about a week ago. Wouldn’t hurt to get the most out of my video card given I spent the money on it. I’m WAY down on Ram (regular RAM not so much VRAM) (Windows 11 is hogging it? Or maybe Asus?), I thought I might have been dealing with a ram issue.
