The main component I’m using is kangaroo2 and
I think the main problem of the grasshopper is mesh weld vertices component that it is stating “the welding mesh with this settings was not successful!!!..output of the original mesh.” I have put a tolerance (number slide) but it doesn’t seem to be working. I think it is the randomized in the beginner I based the beginner code from this tutorial grasshopper kangaroo tutorial - YouTube
If you try to learn K2 from very basic, this playlist would be the least painful and most time-saving way in my opinion.
After completing this, go to Github and try to study @DanielPiker 's example files.
I have thanks. I have looked for solutions on the web and testing different components to fix the solutions and it didn’t work. I have described what was the problem and share the tutorials that I was looking at.
Yes but randomized the spheres. I did some overlap on it on the file with the beginning of the script. I don’t know it will work in one script or should the mesh be flat for it to inflated and then add another mesh to have the spikes.
