Random: File Become read only during file saving
Hello I have a problem with Rinho: sometimes when I try to save the project on the network share the program say: “read only file, use save as for saving file”. Another error is “parameter incorrect” (with red cross). Others programs save files correctly. Someone can help me? I lose hour and hour of work with this issue. Thank you. Sebastian
I had this problem using a script\toolbar installed by SprutCAM. Do you have any plugins or scripts starting external programs.
Mark
Thank you for your response. I try to disable plugins.
Sebastian
