I can’t connect the parallels on some radial networks I am trying to generate. I can’t sort the points correctly.
Radial Grid.gh (12.4 KB)
Missing curves in your input. Or rather, they are referenced, not internalised.
Is this what you’re after?
Only flip matrix fails, because I have more than one polygon, hence the tree becomes more complex.
I see, you’ll need to craft your own conversion using the Path Mapper:
I removed A and C since they’re always zero, B is used to indicate which of the input curves it is, so that one remains intact. The D and index are flipped.
Totally lost here. Can you post that so I can examine it.
Yes! This is perfect. I don’t quite get it though. I will try to understand the logic. Thank you so much.
