in Rhino 9 (WIP) it seems that only no frame and rectangular frame option for annotation leader is working correctly.
Arrow line to text position for Capsule, Circle, Square, Diamond, Triangle, Hexagon, Hex capsule and Rounded rectangle frame is always in the middle.
Size of the Capsule and Hex capsule frame is much bigger (compared to rectangular and rounded rectangle frame with the same mask margin value). Position is also different.
Circle, Square, Diamond, Triangle, Hexagon frames are text content unaware.
Export to dwg (2018. Natural) is losing mask, mask margins and frame around text data for all leader types with active mask.
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 32GB)
.NET 9.0.1
Computer platform: DESKTOP
Standard graphics configuration using DirectX
Primary display: NVIDIA Quadro RTX 5000 (NVidia) Memory: 16GB, Driver date: 7-30-2025 (M-D-Y). DirectX(11)
Secondary graphics devices.
None found.
DirectX Settings
Safe mode: Off
OpenBLAS: OpenBLAS 0.3.29 DYNAMIC_ARCH NO_AFFINITY Zen MAX_THREADS=64.
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V7\VRayForRhino.rhp “V-Ray for Rhino”
C:\Users\Admin\AppData\Roaming\McNeel\Rhinoceros\7.0\Plug-ins\D5Conv (e0d5e210-02f6-4ee9-a2b0-1675e225d958)\0.10.1.0001\Rhino 7\D5Conv.rhp “D5Converter for Rhino”
C:\Program Files\Bongo 2.0 (64-bit)\Rhino6\Bongo.20.rhp “Bongo 2.0”
Hello, arrow line to text position and size of the capsule is resolved, but circle, square, diamond, triangle and hexagon frames are still content unaware even for numbers. When I type in 100, I’m already out of frame. Export to dwg converts all frames to rectangular.
this is somewhat unexpected, having a text frame that does not take into account the length of the text but does take into account new lines of text, and what is strange is that with each new line of text the entire frame moves to the side and away from the arrow.
