R8. how to remove/reposition toolbar separator
here I have my little custom toolbar
slowly growing…
there are a few separators in there, in an incorrect location, how do I move them / delete them ?
and how to insert a separator in the correct location?
Expected behavior = being able to drag a separator to change location.
and being able to drag the separator out to the view port to remove it.
toolbarSeperetors issue
thanks a lot
Akash
With Shift and/or Command keys.
It’s pretty buggy, but if you insist a little bit you can do it
Thanks
Yes a little buggy… mostly the tool-tip is obscuring the view, [so one can’t really see, and it’s a guess work. moving blind pretty much.
I managed to move the separators, but not to remove the unwanted ones… any idea?
I think I got the following to work:
(1) Hold down the Shift key.
(2) Hover mouse over the separator. You should see “Edit” and “Move” pop-up.
(3) Drag the separator off of the toolbar. Rhino should ask if you want to “delete the toolbar item.”
Worked for me. Hope it helps.
In case anybody else runs into this thread.
I just ran into this too, and if there are no icons below the separator it is not possible to remove it (As far as I could figure out) but moving one button below it changed the separtator icon to a vertical line, and then I could move it off the toolbar and choose to delete it.
