In R6, if you select an object, the Boxedit fields are populated and the panel accepts data entry. Then transform the object with, say, a move or a gumball move and the Boxedit fields update appropriately and the panel continues to accept data entry.
In R7, if you select an object, the Boxedit fields are populated and the panel accepts data entry. But transform the object with, say, a move or a gumball move and the Boxedit fields are not updated and the panel is greyed and locked to data entry. To use it you have to deselect the object and reselect it which is inconvenient.
Running Rhino 7.1.20322.15001, 17/11/2020
R6 with nothing selected:
R6 with object selected:
R6 after object move:
R7 with nothing selected:
R7 with object selected:
R7 after object move:
