Box Edit disabled when selecting an object after the other
When changing selection from one object to another, the BoxEdit panel values are disabled until you click again on the same object. Is that a bug or a feature?
It’s a bug. Which version of Rhino are you on? (I see this in 8.9.24163.15301, 2024-06-11, but not in 8.8)
Sorry @jeremy5, forgot the system info:
Rhino 8 SR9 2024-6-11 (Rhino 8, 8.9.24163.15301, Git hash:master @ 17c7f1c7c05ff0e0b5b12288d13a911b1f0767b4)
License type: Commercial, build 2024-06-11
License details: Cloud Zoo
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 32GB)
.NET 7.0.20
Computer platform: LAPTOP  - Plugged in [100% battery remaining]
  Primary display: Intel(R) Iris(R) Xe Graphics (Intel) Memory: 128MB, Driver date: 1-18-2024 (M-D-Y).
        - Windows Main Display is laptop's integrated screen or built-in port
  Primary OpenGL: NVIDIA GeForce RTX 3070 Ti Laptop GPU (NVidia) Memory: 8GB, Driver date: 4-2-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 552.12
OpenGL Settings
  Safe mode: Off
  Graphics level being used: OpenGL 4.6 (primary GPU's maximum)
  Anti-alias mode: 2x
  Mip Map Filtering: Linear
  Render version: 4.6
  Shading Language: 4.60 NVIDIA
  Driver Date: 4-2-2024
  Driver Version: 31.0.15.5212
  Z-Buffer depth: 24 bits
  Total Video Memory: 8 GB
  C:\Program Files\Rhino 8\Plug-ins\Commands.rhp	"Commands"	8.9.24163.15301
  C:\Program Files\Rhino 8\Plug-ins\WebBrowser.rhp	"WebBrowser"
  C:\Program Files\Rhino 8\Plug-ins\rdk.rhp	"Renderer Development Kit"
  C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp	"Rhino Render"	8.9.24163.15301
  C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp	"RDK_EtoUI"	8.9.24163.15301
  C:\Program Files\Rhino 8\Plug-ins\NamedSnapshots.rhp	"Snapshots"
  C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp	"MeshCommands"	8.9.24163.15301
  C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp	"RhinoCycles"	8.9.24163.15301
  C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp	"Toolbars"	8.9.24163.15301
  C:\Program Files\Rhino 8\Plug-ins\3dxrhino.rhp	"3Dconnexion 3D Mouse"
  C:\Program Files\Rhino 8\Plug-ins\Displacement.rhp	"Displacement"
  C:\Program Files\Rhino 8\Plug-ins\SectionTools.rhp	"SectionTools"
  C:\Program Files\Rhino 8\Plug-ins\Calc.rhp	"Calc"
  C:\Program Files\Rhino 8\Plug-ins\Grasshopper\GrasshopperPlugin.rhp	"Grasshopper"	8.9.24163.15301
Thanks for the report, I see the same issue here as well.
RH-82612
I just noticed, the BoxEdit values are disabled after a gumball rotation or scale operation.
And If the panel is docked and partially obscured (picture) I can’t scroll it down when it’s disabled (not an issue imo).
Thanks, we were able to spot the issue and get this patched today. It has gone to internal testing and will roll out in an upcoming service release.
Hi @Trav, sorry to bother again with this issue.
The initial bug was solved, but it appeared in another way.
When dealing with multiple objects, the BoxEdit is disabled, and will only turn on when changing tabs in the docked layout. I have several tabs on this panel, so I don’t know how to solve the issue if you don’t have another tab to go back and forth.
In the vídeo you can see that after the OffsetSrf command, the values are disabled again, even that I kept the original objects selected.
(I have the habit of selecting the objects before most commands, so that Rhino keeps the parent objects selected after the operation is done)
Here’s my Sysinfo:
Rhino 8 SR11 2024-8-13 (Rhino 8, 8.11.24226.06001, Git hash:master @ bdb34e68e0160956fc5633ba163aeb8fe1301c50)
License type: Commercial, build 2024-08-13
.NET 7.0.20
  Primary OpenGL: NVIDIA GeForce RTX 3070 Ti Laptop GPU (NVidia) Memory: 8GB, Driver date: 7-10-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 560.70
OpenGL Settings
  Safe mode: Off
  Anti-alias mode: 2x
  Render version: 4.6
  Driver Date: 7-10-2024
  Driver Version: 32.0.15.6070
  C:\ProgramData\McNeel\Rhinoceros\8.0\Plug-ins\Datasmith Rhino Exporter (d1fdc795-b334-4933-b680-088119cdc6bb)\DatasmithRhino8.rhp	"Datasmith Exporter"	5.4.2.0
  C:\Users\user\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\SubstanceImporter\2.0.7\Substance.Win.rhp	"SubstanceImporter"	2.0.7.0
  C:\ProgramData\McNeel\Rhinoceros\packages\8.0\Grasshopper_Gold_Tools\1.0\Grasshopper_Gold_Tools.rhp	"Grasshopper_Gold_Tools"	2.0.0.0
  C:\ProgramData\McNeel\Rhinoceros\packages\8.0\ToolPanel\1.0\ToolPanelV2.rhp	"ToolPanelV2"	2.0.0.0
  C:\Program Files\Rhino 8\Plug-ins\Commands.rhp	"Commands"	8.11.24226.6001
  C:\Program Files\Rhino 8\Plug-ins\RhinoScript.rhp	"RhinoScript"
  C:\Program Files\Rhino 8\Plug-ins\IdleProcessor.rhp	"IdleProcessor"
  C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp	"Rhino Render"	8.11.24226.6001
  C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp	"Legacy Rhino Render"
  C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp	"RDK_EtoUI"	8.11.24226.6001
  C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp	"MeshCommands"	8.11.24226.6001
  C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp	"RhinoCycles"	8.11.24226.6001
  C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp	"Toolbars"	8.11.24226.6001
  C:\Program Files\Rhino 8\Plug-ins\SolidTools.rhp	"SolidTools"
  C:\Program Files\Rhino 8\Plug-ins\AnimationTools.rhp	"AnimationTools"
  C:\Program Files\Rhino 8\Plug-ins\Grasshopper\GrasshopperPlugin.rhp	"Grasshopper"	8.11.24226.6001
  C:\Program Files\Rhino 8\Plug-ins\import_GHS.rhp	"General Hydrostatics (GHS) Import"
ps: sorry if my mouse movements make me seem like I’m on crack. I am not.
hmm that sounds similar to the fixed issue for sure.
However I see that you’re on SR11 so I need to poke around and see if I can repeat what you’re seeing.
Im able to repeat by just making a box and sub object selecting a face and extruding with the gumball. I was also able to fix the issue while I was trying to understand the problem. RH-83359
I am still seeing the same problem in Version 8 SR9 (8.9.24194.18121, 2024-07-12).
@Hermes2024 yes, I was just testing the fix for this, which will be in 8.12
Thank you Gijs!
Some feedback: I upgraded to Version 8 SR10 (8.10.24226.13001, 2024-08-13) this morning and so far it is behaving well. I have not encountered the Box Edit disabled when selecting problem, but will keep an eye on it. Thank you for the fix.
