Quickly Loft
Hello everyone,
Unfortunately, I have 2x800 curve. How can I do these quickly instead of loft them one by one?
An alternate method would be to make a single diamond, arrange them along a flat plane using Array, and then use FlowAlongSrf to map that flat array to the shape of your final form.
Unfortunately, it was not a suitable surface for FlowAlongSrf and was deformed. I had to draw the curves myself.
Maybe try using these options:
FlowAlongSrfNoDeformation.3dm (4.0 MB)
I think with the right options and inputs, you should be able to get it to work.
-Sky
Can you share the file .To help you
