Quick way to import points in Rhino
Dear friends,
I’m trying to import a set of points into Rhino with as little preprocessing as possible in Grasshopper. I have the X,Y,Z coordinates in an excel file. In Excel, I can prepare the format of the points that are necessary. What is the fastest way to do it?
Thanks in advance
3. Attach minimal versions of all the relevant files
Have x, y, z in separate columns and use pancake to read the excel file. Pass the output into construct point
Alternatively, save the excel as a csv file and use python’s built in csv reader
points_from_csv.gh (7.4 KB)
points.csv (103 Bytes)
Thank you for your answert. Sorry if I didnt explain my problem properly
I have a excel file with a different number of points in each columns. Each column represent a curve I need to represent in Rhino like a pipe.
I´m looking for the quickest way import and plot de data in Rhino.
Thanks in advance
Send/upload the excel file
Fastest Way:
Take them into a textfile in this format: “X,Y,Z” = “10.5,20.3,2.3”.
Select all → CTRL+C → Go to Rhino create point → press CTRL+V = U get all points.
To create these format use the programm “Notepad +” there u can search and replace. with CTRL + F
U can also use Excel to place the maybe seperated (X Y Z data) from A B C into D in this format X,Y,Z
Way.2:
Import.gh (11.9 KB)
Here is a Script, it will help u to understand how to do it with multiple files.
1.Seach and read files in a path
2.Read files
3.get the Coordinates and create Points
4.Bake the Points on a Layer with the same name of the File.
5. The script is creating polylines out of the points
6. Then u can add component “Pipe” and “cap holes” to create 3D
(U dont need to do 1-5, the script is doing everythink, simple add the Path and press the Button)
I used it to import 40 textfiles, with each 10 coordinates to create lines. With 1 click.
Text files needs only contain “X,Y,Z” “10.5,20.3,2.3” This format.
The path should only contain the textfiles.
Save file as CSV out of excel. Then open the CSV with Rhino:
