Quick help required opening DWG - empty
when I open these DWG, empty … not sure why, can anyone please help and save so I can use?
many many thanks
Oasis Linear Duo Pod.Left Hand Door.Glass Rear Wall.dwg (1.5 MB) Oasis Linear Study Booth (LH Door).dwg (579.6 KB)
Hi Richard -
Here’s one so far.
Oasis Linear Duo Pod.Left Hand Door.Glass Rear Wall-TrueView.dwg (1.4 MB)
The other one doesn’t want to read in TrueView either, I’m afraid…
Rhino also skipped 62 objects.
excellent wim! thank you so much
why does rhino skip certain objects?
Good question. : )
In the case of that file that TrueView couldn’t open, I’d say that these objects are somehow damaged beyond repair. I put the other one on the pile for a developer to take a look at - RH-62294: File IO: DWG import failure case.
thank you
Hi Richard -
The developer asks about the history of those DWG files.
Do you know in which program they were originally generated?
Wim
I dont, please dont waste anymore time as I have moved on now to next project!
Thanks for your help
Rich
more dwg issues…
opens fine in 3ds max - but not rhino 6 or 7…
DFT001.DWG (2.5 MB)
Opens OK here in V7…
sorry, yes it opens but the model is wrong… the image in 3ds max is correct, why are they not the same?
thank you
Yep, didn’t look closely enough, sorry. The arm parts are missing. I see this:
So, there is something about the definition of those objects that Rhino doesn’t like and they get skipped on importing. I don’t know what that might be however.
thank you
