Questions about Rhino Inside
I am a little bit confused about Rhino Inside; it would be great if somebody can answer my questions:
  1. Can I use Rhino computing to do geometrical manipulation within my application? I mean to do boolean operations, intersections and so on… (basically, like use it as a geometric kernel)
  2. Should the users have Rhino (7?) installed for that?
  3. What is the licensing scheme you will be using for this? If I want to use it within a software that I will be selling?
Thanks in advance!
Questions one and two are answered with
For three the answer is the same as for regular Rhino. Since you need a valid Rhino installation you need a valid Rhino license. Or your users will that, rather.
I see. Thanks for your answer!
