According to Rhino Inside samples like “Rhino Compute” and “ConsoleApps”, there are two different ways to use Rhino Inside.
sample Rhino Compute link : https://github.com/mcneel/compute.rhino3d/blob/master/src/compute.geometry/RhinoLib.cs
sample Rhino Inside ConsoleApps : https://github.com/mcneel/rhino.inside/blob/master/ConsoleApps/HelloWorld/Program.cs
In Rhino Compute, there are two steps to use Rhino Inside as follow.
step 1 : load RhinoCommon.dll
step 2 : call LaunchInProcess in RhinoLibrary.dll
In ConsoleApps, there is only one step as follow.
step 1 : just load RhinoCommon.dll
can you tell me what is the difference between two samples.
and is there a guideline to use Rhino Inside?
one more, can I run a web application using Rhino Inside on .Net core not .Net standard framework?
and how about running above web application on Window Server Core not Normal Window Server?
Thanks.
