Hello everybody
Does anybody know a easy way to unroll this surfaces ?
I can only handle one surface at a time, so I have to put everything together at the end.
is it easier?
Tragwerk.3dm (3.4 MB)
Thanks a lot for your answer !
Hello everybody
is it easier?
Hello - no file was included but UnrollSrf
works on joined polysurfaces as well as surfaces - you need to pay attention to the command line setting for Explode=Yes/No.
Thanks for your answer !
i’m sorry, now the document should be uploaded
So I think the problem is that the surfaces are not in tolerance, so I can not join them
that is too bad
Hi Milena - if I am reading this correctly, there are basically just two surfaces, repeated in an arc pattern - is that correct?
yes exactly
Hi Milena - so, you can unroll one of each and then copy these if needed afterward - am I correct or am I missing the point of your question?
Hey Pascal
yes, but then I have to turn off and place each one at the right angle. Because I want to have the flat network and not just the individual bars…
