I have a model that the unrollsrf command will operate well on individual surfaces when it is exploded. But when I try to unroll the whole thing as a polysurface the operation splits the surfaces up into a million pieces.
The model goes from 238 surfaces to 683 surfaces and puts labels every couple inches. I’d really like to have labels on this because it’s kind of a tricky sculpture so unrolling it as a polysurface is my strong preference. Has anyone run into this?
@20digitdesign - many of the surfaces have curvature discontinuites - that is, they are only tangent continuous internally. These will become polysurfaces on unrolling.
Thanks Pascal. I’m not really sure what that means. When I unroll just one surface the command works great. When I do it as a poly it shatters. Should I just do regular lofts instead of developable lofts and then it might work all as one unit even though the surfaces will be a little more distorted?
Hello- the bit that I looked at also made a polysurface from one unrolling just the surface. Let me poke some more. @20digitdesign - it may be that the result is misleading because grouped, for the single surface case. Here I get polysurfaces, unrolled.
