Hi guys! New here, so please excuse me if i violate protocol somehow.
I am having an issue with the “unroll developable surface” command I have 2 identical surfaces. One of the surfaces is a polysurface, and the other has been merged into a single surface. When I unroll both of them, the merged surface comes out shorter than the polysurface. the unrolled polysurface is correct when I do the math. Why is the merged surface unrolling at a different length?
Thanks for the heads up! I have attached the .3dm file (not sure how to attach it to the entire thread)Unroll surf.3dm (88.1 KB)
Let me know if I did this correctly.
I used Rhino V6, and the file was saved in Rhino V6 format which can’t be opened by earlier versions. Here is a version saved in Rhino V4 format. Unroll surf DC01 V4.3dm (166.7 KB)
I also tried unrolling the surfaces in V5 and the results were identical to V6.
My vague recollection is UnrollSrf may have been updated for V5.
Can you upload a file with your unrolled surfaces?
Nothing obvious to me. As I previously mentioned my recollection is UnrollSrf may have been modified and improved for V5 compared to V4. V5 was released circa 2012.
