RH-45147. As a workaround you can set the advanced option RhinoCycles.SaveDebugImages
to true. When you then use the view capture commands you’ll find at the end of the process in %TEMP%
is created. This is the result of the Raytraced
view capture. The blank renders you see are due to an OpenGL problem which is being investigated and fixed. The hacky workaround should give you the Raytraced
results you are looking for. Remember to turn it off after a view capture, as it will also write out intermediate results and textures for a regular Raytraced
view - it can be a slowing factor.
