Question about the Bake Geometry from Human Tools
Dear sir Andrew,
I have problem with the “Bake Geometry” from HUMAN, when I will bake (per example the Dot Display or the Custom Preview Component) with this procedure.
The error log is “Data conversion failed from Goo to Geometry”
p.s.: I use this step with the Human UI windows.
Thanks, and have a nice day!!
Greetings from Munich
I think you are mixing up two different approaches; you are passing a set of Grasshopper components to the “bake geometry” component instead of passing geometry. I am not sure what you want to happen by baking a custom preview component - this component has no bake functionality. As for the dot display, this can be baked programmatically using “Bake Object” from metahopper, something like this:
Hi Andrew,
I want to create a button in Human UI to bake my final geometry in grasshopper (without going to the grasshopper script). As I am not familiar with C#,I was wondering if any has done it before?
Thanks
Sadra
