Hi there.
I’m wondering if it’s possible to bake groups of objects to input layers.
I’m not entirely sure I understand how Human works, but this attempt didn’t
Cheers,
Jeremy
Hi there.
Cheers,
Jeremy
Hey Jeremy,
There are few things that you need to check before using the ‘Bake Geometry’ component.
*First, make sure the Geometry input doesn’t have a null object. You can do this by using a ‘clean’ component.
*Second, the Attributes input of ‘Bake Geometry’ requires the ‘Create Object Attributes’ component to work. This component allows you to set the layers and many more Rhino properties.
Just make sure the Geometry and Attributes inputs of ‘Bake Geometry’ have matching tree structures and no nulls.
Hope this helps.
Rolf
