Thank you for taking the time to read my thread. I’m having a problem with baking geometry from the Human UI plug-in. I’m trying to bake different geometry in specific layers in Rhino using Elefront components. Apparently there is a problem that i can’t seem to figure out: there’s an error in the Elefront component saying “Please double-triple check your data tree structures to see if they all line up”. I tried flattening the data tree but it didn’t seem to solve my problem. Hence why I’m asking for your help.
Thank you again for your time !
Below is a screenshot of my work showcasing both the error and the algorithm.
@Japhy geometry from a pipe component is going into the V, as for the key i just added 0 key1 and still receive the same error message.
Note that there is no null values in the geometry tree.
Hey @ralphkarkafi. Geometry shouldn’t go into the V input. The V input is for adding values (for key-value pairings). I’ve attached my script for you to see/copy/edit. Might save @Japhy having to edit yours.
