Question about SetPerFaceColorByFacePack in Rhino 8
I’m working on a SubD sofa model and I want to assign different colors to specific areas, such as the backrest, seat, and armrests, using the command SetPerFaceColorByFacePack.
I’ve tried several times but haven’t figured out how to control the Face Packs and assign colors to the areas I want.
Could someone explain the correct workflow or share a tutorial?
Thank you!
you can just sub-select Faces:
windows: ctrl+shift+leftmouseclick
mac: cmd+shift+leftmouseclick
then assign a custom color in the _properties panel
as fare as i understand _SetPerFaceColorByFacePack is more to preview how _toNurbs will pack faces.
kind regards - tom
Thank you, Tom. My main goal is not just to color the SubD faces, but to use these colored areas as separate parts after converting the SubD to NURBS with _ToNurbs.
For example, if I select and color the backrest, seat, and armrests separately, will _ToNurbs convert each colored area into a separate NURBS surface or group of surfaces?
This is very important for my furniture workflow.
there is already another topic about this - but not answered / no solution:
i think @pierrec is the one in charge of this (?) - or at least knows who to address this issue to?
if you do not care about the (huge) amount of CV’s:
a bricolage-workaround:
ToNurbs without face Packing
then _mergeSrf until you reach the desired face-Structure…
you might finish with a _fitSrf
you can also _split (isocurve, shrink=yes)
and combine this with _mergeSrf
@ANEGUER_ABDELAZIZ maybe change the title / topic to something more like “toNurbs - custom facepacking” ? (you can still edit the title, there is a small gray :pencil: icon below)
Hi Aneguer, just in case you want to use these separate parts to be fabricated from one piece then this is possible but it takes some extra steps. Can you share a model?
Jess
