I’d probably create that manually with mesh faces…most of them being 3-sided. Or use subd tools but just don’t toggle to smooth mode.
Could you give it a try with 3DFace ?
Tanks alot
I will try it…
You know, some of the surfaces are not triangles. What should we do in this case?
just use SrfPt. if you have even more than 4 edges use a polyline and use PlanarSrf on it. if the Polyline is not planar use Patch.
There is no limited on the number of edges to 3DFace. You can create Triangle, Quad, or Ngon object, as demo below.
Tank you so much…
if i want to make glass surface between layers wich command is suitable?
Tank you…
Can you draw a sketch to illustrate your needs? Thank you.
