Hi I’m an architecture student, an I’m having trouble using the Make2D command in Rhino. Whenever I create a clipping plane and then run Make2D, some objects and lines don’t appear in the resulting 2D drawing, even though they’re visible in the 3D model. I’m not sure what’s causing this or how to fix it. Has anyone experienced this issue before or knows what might be causing it? Any advice would be greatly appreciated. Thank you!
@Hirokazu_Yamakura It is easier to help you, if you provide pictures of the issue and a file to test.
Toni_Osterlund Hi, I sincerely apologize for the late reply. For some reason, I never received a notification that you had responded to my post.
Anyway, this is the issue I’ve been dealing with. Some of the objects don’t even show up in the Make2D output.
