Hello! My name is Ece. I am an architecture student. I need urgent help about an issue in Rhino. I made my model and by using clipping plane, i screened a plan of it. Now I am trying to use Make2D command to make it 2d and then export. But the command is not working as it should be. It makes the layering but does not show the 2d lines. But when i select the objects from the make2d layers, it chooses but still not showing them. I really need it to work urgently, so please help me. I am adding the google drive link of the rhino file here. Thanks!!
If i understand correctly the objects from the Make2d are being placed above the clipping plane, hence selected but not seen.
Change your view to one not clipped.
