Querying Elements by Subcategory in Rhino.Inside.Revit Grasshopper
In Rhino.Inside.Revit Grashopper, is there a way to choose Elements by Subcategory?
For Example, I have bunch of Model Lines I’ve sorted by Line Style.
Is there a way to select or identify only the Lines with that specific subcategory (Line Style) once I bring them in?
There is no dedicated component for this, but you can build your own using a cluster like this one.
RiR-QueryModelLines.gh (13.6 KB)
Amazing! Thank you much @kike!
Hi Kike, is there a way to get access to the Subcategories in Detail Item from a project file? For instance, get which family types are using one selected Detail Item Subcategories. I tried connect the “Element Subcategory” with an detail item instance, it returns “null”.
Hi Hali,
Detail items are View dependent, try something like this…
Hi @Japhy,
I have also same question.
What “Element Subcategory” component uses for?
I see we can use Element Geometry component to get the geometries of subcategory…
I am just trying to find out the usecases using “Element Subcategory” component. Cannot come up with the ideas as the output of Subcategory is Null…
If you can get/set the subcategory if available.
Hi @Japhy,
aha… it works in Family Editor…
Thanks for the help!!
How could this be used to select a specific line style of detail line from a view?
Edit - this worked
Thanks!
