Ok, good to know, then I had sat that manually too…
Bad news again - “3D App - default global settings” cause a lagged responsibility of Rhino if the model is complex. For example my current project: a train, typical frame rate 2fps. If I move the top view camera and immediately jump to the perspective view and rotate it, than the viewport shows a reaction after one second freeze only. If I use the “workstation app - dynamic streaming” than the Rhino shows an immediately reaction.
This is only one example, the Rhino UI lag in 3D App mode is to much, not good for working. So, this mode is good for tests only, not to enhance a slow viewport. This nice dream is over.
Ah, OK.
The lag issue was what put me on the hunt for a better setting and that’s when I discovered the “workstation” mode.
But I don’t experience that problem now, maybe due to smaller files. I’ll check. Just upgraded to the latest drivers.
I am not clear what you are saying here. Do you mean that the Dynamic streaming mode is an improvement over the 3D App settings for large models, because there is immediate reaction to viewport switching. But, the UI can still lag on large models? So, it does not solve all your performance issues on the largest models?
Thank you for your information in this thread also: Video card again - Quadro disaster
@John_Brock I updated the page with a little more direct language.
No matter which Nvidia mode I use, my complex project files give me frame rates around 1…2 fps. The “3D App - default global settings” show me much better times for the 100 sphere test, but I got no improvement for my large project files (also for the medium complex bike model). Also the “3D App - default global settings” cause short UI freezes during a large model is open. Per Dynamic streaming mode I don’t get UI freezes. So, the dynamic streaming mode works much better for large models.
I see, thank you for the clarification.
We have been seeing the dynamic streaming mode help with stability in the past. I am not clear with this new driver if the stability is helped with dynamic streaming or not. We have not had enough time with the new driver yet.
The dynamic mode does the job like in the past. It doesn’t solve the problem of the slow FPS, but doesn’t bring new problems.
I’ve only got a lowly 2000D… should I update?
If the supported model section on the driver description lists your card as supported then I’d say yes.
That said, I’d be sure to make a manual Windows System Restore Point in the event there is a problem.
If you search using this page, the 340.66 driver update does support the 2000D card: Official Drivers | NVIDIA
Hi @Micha, In the new 340.66 Quadro Driver I noticed that there is a new Option at the bottom of the list.
There is the old Workstation App - Dynamic Streaming, but there is a new option called Workstation App - Advanced Streaming.
I am getting similar performance times as I did on the 3D App - Default Global Settings, and no noticeable delays on my Quadro6000. Perhaps try this new Nvidia Control Panel option.
I set mine to Advanced Streaming and then Set the Power Management to Prefer Maximum Performance again.
It seems to reset this back to Nvidia Controlled each time you change the option.
Edit: I’ve also noticed that Max Performance mode causes the GPU to run at top clock speed of 574Mhz (And top temperature) as long as Rhino3D is open. As soon as I close Rhino3D then the GPU gradually downclocks itself to 51Mhz in normal Windows Aero mode to save power and heat. Not a problem, but interesting that if you leave Rhino running(even minimised) the GPU does not downclock. Under Nvidia Controlled settings the clock speed would jump around between the 4 x power speeds contantly even with Rhino open.
Yes!
This works great here as well! It seems all the old Quadro issues are gone (so far).
(Edit: My only issues were either speed or microlagging. The card was always stable.)
I’ll use these settings now and I’ll keep you posted. (Quadro 4000, win 7)
I hope this is a real solution. I know the emphasis has always been to make Rhino work on the most cards as possible, but the desire for inclusion seems to have made Rhino not work fantastically on any card; and I feel it is important for you guys to know that, at least in my field, it is starting to cause a migration away from Rhino to other packages. People have grown frustrated with the disparity in display speeds between Rhino and other software. Trying to show a supervisor or a client a slow tumbling model is much less than ideal, or trying to use and navigate layouts with multiple details proves almost unusable if you don’t hide everything or turn details to wireframe. That is not acceptable for us in a professional setting, and I hope it is unacceptable for you was well.
I would like urge McNeel to not underestimate the needs of their professional users. If you continue to only cater to the casual or educational user, you will lose those who need exceptional performance from their software. If you need to employ more tricks to improve speed, then do it. If you need to charge us more for it, then do it, but please make it available to those who want and need it.
Hello @John_Brock @jeff @scottd, I found this PDF from Nvidia online with some vague but interesting info regarding these Quadro options. It is from 2012 so perhaps there is a newer version of this document.
Page 38 is most interesting regarding preset Quadro Modes.
http://on-demand.gputechconf.com/gtc/2012/presentations/S0341-Monday-See-Big-Picture-Scalable.pdf
I also thinks it’s time we start asking for our own Profile to be included with their drivers. This was mentioned a couple months ago by them, and it looks like we’re zeroing in on what that profile would look like.
I invited Digvijay to weigh in on this conversation using the Invite button below. I’ll also email him, as there wasn’t a way for me to put any personal comments in the invitation.
This thread suddenly went very quiet. Has the new setting solved everyone’s quadro problems?
