Quad panels with varying extrusion for midpoint
Hi there! I’m trying to create a diamond grided panel system as per the screenshot below (manually made in sketchup) where the depth of the panel to the tapered point varies based on attraction to a curve and 2 point along the same. As a next stage, I would like for the grid also to bulge along these anchors.
The issues I’m facing are
  1. I tried extrude to point, but I cannot seem to get the panels to extrude to the boundary of the individual panel only - instead, the extrusions are happening from all the curves, leaving me with a nest of extrusions.
  2. The meshes for the edges and SOME of the panels are further subdividing or losing shape and I can’t find the source of the problem.
  3. I am able to deform a rectangular grid itself when I do it separately, but am not able to actually build the geometry within this deformed grid. Tried Map to Surface and then plugging things in as well but no luck so far.
    DiaGridPanels.gh (11.5 KB)
    DiaGrid.3dm (63.8 KB)
Truth be told, I have not touched Grasshopper in ages so I know I’m making some super obvious but dumb mistakes. Any pointers would be very much appreciated!
DiaGridPanels Edited v0.gh (18.7 KB)
Thank you very much for that Quan! You nailed the deconstruction of the edges- much appreciated.
