Hi guys, Hope someone can help complete this grasshopper definition.
As you can see on my attached images, I’m trying to build a diagrid facade with thickness.
Couple of things I’m failing to do is extrusion to normal, I think I did what I should do but diamonds are overlapping each other when extruded, especially all edge triangles created by ‘clean tree’ are extruding downwards. (image attached)
*because the surface is curving, some overlapping won’t be avoidable so I will be happy if I can fix all the edge triangle extrusions…
Second thing I would like to achieve is offset of each diamonds modules so I have gaps between them. (image attached)
DIAGRID FACADE_test.3dm (270.1 KB) Diagrid facade_test.gh (14.8 KB)
